Just now, Abir.legend said:
i have these screenshots what is happening ?
imageproxy.php?img=&key=0c2a8b7d8afbc61aimageproxy.php?img=&key=0c2a8b7d8afbc61aimage.png.650ffc7320f039dd11fcea44e83b57c1.png
this happened after driver update before it was 2048 mb
The driver was not installed correctly,you can reinstall the new driver and if that doesn't work just use the old one.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
which one is correct ? i installed both from dell's actual support page
The one that say:
Inte(R) HD Graphics Family
is the correct one.
