I currently have a i7 3770 and a rubbish little mATX Gigabyte board. Should I upgrade my board or should I wait for the next generation and get an unlocked CPU and a good ATX board?
Desktop: Intel i7 3770 - Gigabyte Z77 D3H MVP - 16GB RAM OCed to 1400mhz - EVGA 760 4GB ACX FTW Edition & Gainward GTX 650 1GB - 128GB Kingston HyperX SSD - 2TB Hitachi HDD - Windows 8
Laptop: Alienware M11x r3 i7 - 8GB RAM - GTX 560m - 750GB Seagate HDD - Windows 7
SEND ME ALL YOUR BITCOINS: 1PPkGGMKT3RpjjVVDCMZ3GXf6TvHimWDBE
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/
From what iv'e read haswell is more advancing with the integrated gpu and controllers, and not much with the cpu itself.
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120786
I think you should just buy a new z77 motherboard. Haswell is only going to improve about 10-15% in performance and you will spend more than it is worth to get the new cpu as well as the motherboard. An i7 3770k is a great processor and there are many great z77 motherboards.
PC Specs: Intel Core i5 3570k @4.0 GHz - Asus P8Z77-V - Corsair H60 - 16 GB Corsair Vengeance 1600 MHz - 2x EVGA Nvidia Geforce GTX 670 FTW - 120 GB Corsair Force Series 3 SSD - 1 TB Seagate Barracuda 7200 RPM HDD - NZXT Phantom 410 Black - Cooler Master Silent Pro 850w
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120789
Only reason that I'd considered getting Haswell was for getting an overclockable CPU
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120790
Unless your doing video work or something CPU intensive, you don't really need to overclock we just do it for fun. But it's nt worth spending hard earned cash for that minor boost ^_^
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120806
Any ideas for a new 1155 ATX board? Needs at least 5 SATA and support for both SLI and Crossfire.
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120822
New motherboard. The 3770 is fantastic (unless you've realised you've made a mistake by not buying the unlocked version ;) )
Desktop: Intel Core i7-5820K, Corsair H115i, Asus X99-Deluxe/USB 3.1, G.Skill Ripjaws4 32GB 2800MHz CL16, Zotac RTX 3070, Samsung 950 Pro 512GB in Angelbird Wings PX1, Samsung 850 EVO 1TB, 5*Seagate 12TB, Cooler Master V1200, Phanteks Enthoo Luxe, Windows 10 Pro. Phillips 328P6VUBREB, Corsair Vengeance K95 RGB Cherry MX Brown, Logitech G502 X Plus, Sennheiser HD700.
AYANEO 2S: AMD 7800U, 32GB 7500MHz, 2TB WD SN850X. Windows 11.
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120826
ASUS P8Z77-V Pro. Budget?
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120828
My rig came with a non 'k'
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120830
I was only kidding. The 3770 is fantastic :)
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120833
On the P8Z77-V LK, there are 2 SATA 3 ports and 4 SATA 2 ports and it supports Quad-GPU SLI and Quad-GPU/3-Way CrossFireX Support.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120840
Is it just me or do us Aussies have to pay heaps more for gear like that though
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120841
What would you recommend from here: http://diycomputers.com.au/cat2.asp?catid2=595&catid=455
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120850
It is about 5 to 10% more, sadly :( but because our prices have GST included, the difference isn't that great if you count the money going out of your pocket. I find pccasegear and techbuy has most of the stuff you need for a computer.
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120863
I use pccasegear or if I want to actually buy it from a shop I go to DIY computer warehouse
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120870
In Canberra, the only decent store I know of is one in Fyshwick http://www.msy.com.au/
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120886
There's a couple of them up here in SYD
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120895
The ASRock Z77 Extreme4 if you are on a budget or a GIGABYTE GA-Z77X-UD3H.
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120902
Yeah, the seem decent enough. Anyhow, in terms of motherboards, go with anything from ASUS, Gigabyte or MSI. I'll be better able to help you if you give me a price range :)
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-120910
~$150 Thanks for the help
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-121981
Asus P8Z77-V LX, 135$ on the DIY store. Great motherboard :)
Gigabyte Z77X-D3H, 158$. For the extra 23$, you get more USB 3.0, more SATA, better audio (I have no personal experience with this motherboard, but I've heard it is good), mSATA support, USB quick charge. They also claim to use better materials than other manufacturers.
I have had no trouble with Asus stuff, and I'll admit I'm a little biased toward Asus, but Gigabyte is just as good, sometimes better. Depends whether you want to pay 20$ more for the mentioned.
EDIT: The colour scheme of the Gigabyte is so good! :D
https://linustechtips.com/topic/11326-should-i-wait-for-haswell/#findComment-122855
