help needed for gaming PC build
26 minutes ago, Aidan.69420 said:county is canada, budget is between $1300-1700 CDN. PC is for gaming and ill use it on a 1080p 144hz monitor.
Really don't need a 2070 super for that resolution, the RX 5700 has 80-90% the same performance depending on overclocking or flashing it.
For some reason memory pricing is high in canada for 3600mhz CL16 RAM, don't really need 32GBs of RAM, and it's harder to run that at higher frequencies, though 3200mhz CL16 16GB * 2 kits shouldn't be too expensive.
Just threw together a best value list basically. You can spend more money, but for strictly gaming the performance gains won't be too high.
Also don't cheap out on your power supply.
You can also just get an MSI B450 board, the VRM will be fine for even the 8 core, just need to add in a wifi card.
PCPartPicker Part List: https://ca.pcpartpicker.com/list/NczdHB
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($259.50 @ Vuugo)
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard ($244.99 @ Mike's Computer Shop)
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3200 Memory ($80.99 @ Newegg Canada)
Storage: Intel 660p 512 GB M.2-2280 NVME Solid State Drive ($79.99 @ Newegg Canada)
Video Card: Sapphire Radeon RX 5700 8 GB PULSE Video Card ($483.50 @ Vuugo)
Case: Fractal Design Focus G ATX Mid Tower Case ($68.99 @ PC-Canada)
Power Supply: Corsair RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($99.99 @ PC-Canada)
Total: $1317.95
Generated by PCPartPicker 2019-12-07 18:09 EST-0500
