Hi everyone,
Not 100% complete, waiting on some RGB light strips to come in to get those extra FPS and it can use a bit better cable management. But I was excited to show off my first time building. I've been watching a lot of LTT videos and other YouTubers on tips on how to build.
So to give some context where I started.
I originally bought a refurbished HP-Omen 870-217 - Then I slowly started to upgrade that pre-built only to realize... it's a pain, as the case was small, Mobo was small, made it hard to fit a RTX 2060 comfortable, couldn't cable manage how I wanted to, PSU was terrible.
So I took that whole kit and basically rebuilt and only kept 3 items
i7-7700 Processor
120GB SSD with the OS
1TB HDD
Was really fun to put together my first pc! ? Still troubleshooting some issues but she's purring.
Everything else are pieces I've picked up and swapped :) PCPP List for reference at bottom (please note the Storage is not accurate):
Before Image:
After Image:
https://linustechtips.com/topic/1132061-my-first-build/
Pretty stylish, what price did you scoop the mobo up for?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1132061-my-first-build/#findComment-13109268
No sale so got it for $159. During Black Friday Weekend - i was looking for any deals but since I have a 7th gen processor I didn't see many deals. All the mobos i ran into were for 8th and 9th gen chips.
https://linustechtips.com/topic/1132061-my-first-build/#findComment-13109276
Ouch, always best to buy last gen Intel hardware used fyi
Primary PC:
PSU tier list
https://linustechtips.com/topic/1132061-my-first-build/#findComment-13109320
Just quick question, did you mount your cpu cooler opposite direction?? Looks like fan on cpu cooler is blowing air inside of the case
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1132061-my-first-build/#findComment-13113502
