Hello this is my very first build I was on a tight buget so the case has the worst cable manageing or im just bad at it. There was no whole for a CPU connector so theres another ugly cable. The case also had no dustfilters so I got someting that I thought would work and slaped it on there. Sorry about the bad pictures.
CPU: AMD-FX 4100 OC to 4.2 GHz
GPU: Sapphire HD 7850 1GB
Motherboard: Gigabyte 990FAX-UD3
RAM: Patriot G2 series 8gb (2x4gb)
Cooler: Zalman CNPS5X performance
PSU: Roswill 700W
Hard Drive: Seagate Momentus XT 750GB (Mounted to my side panel with velco.)
post-6272-0-29819700-1367116073_thumb.jp
The Hard Drive is the blude PCB in front of the front intake fan.
post-6272-0-43067800-1367116096_thumb.jp
post-6272-0-84023200-1367116187_thumb.jp
post-6272-0-23100100-1367116139_thumb.jp
A man without a filter is just chaos walking.
https://linustechtips.com/topic/11312-first-build/
Nice starting pc build! I also like your use of dust covers on the case. Hopefully you can enjoy gaming on your new build!
PC Specs: Intel Core i5 3570k @4.0 GHz - Asus P8Z77-V - Corsair H60 - 16 GB Corsair Vengeance 1600 MHz - 2x EVGA Nvidia Geforce GTX 670 FTW - 120 GB Corsair Force Series 3 SSD - 1 TB Seagate Barracuda 7200 RPM HDD - NZXT Phantom 410 Black - Cooler Master Silent Pro 850w
https://linustechtips.com/topic/11312-first-build/#findComment-120684
