https://linustechtips.com/topic/1128775-new-build-need-final-advice/
Hey Dude, that is a solid build! nice psu, it will allow you to upgrade your gpu in the future if you feel like it :)
edited bc @Jurrunio is right about that specific model of psu:
NeXTcube 12400 Z690M ITX 64GB SN770 6600XT Sugo16 12.5
NeXTserver 9400 H310N ITX 32GB SN350 5500XT Fara R1 12.5
NeXTstation 9900K Z390 ITX 32GB SN750 6800XT Enthoo 12.5
spent way too much for the CPU (and the platform if AMD is considered) and SSD compared to the graphics card (assuming it's a gaming rig, not an adobe only machine), case airflow is mediocre, PSU that's overkill in wattage but can't power high power draw components properly with its OPP issue.
Desktop benching:
Thank you for the feedback! So the psu is too much wattage? Would I be better off keeping the psu and upgrading to a higher level graphics card? If so what would yall recommend? BTW I'm using this computer for trading and gaming. I based most of my part decisions off of this website.
https://www.blueauracomputers.com/trading-computers-buyers-guide.php
I think the wattage is ok, specially if you are going to be upgrading your gpu in the future or maybe adding a multi displays for trading. Just out of curiosity which platform are you currently using?
Hugosway
