Help me
Go to solution Solved by Slottr,
Install windows onto the hard drive
https://linustechtips.com/topic/1128014-help-me/#findComment-13080161
9 minutes ago, MeGhoul said:
It's not detecting old hard drive detecting ssd
Can you list your specs and your situation more thoroughly? I'm quite confused.
Also make sure to quote when you reply so I get notified
https://linustechtips.com/topic/1128014-help-me/#findComment-13080213
