Hi. I'd like to create a VM in Virtualbox to run High Sierra 10.13, as it, as far as I know, doesn't support 10.14 and I definitely don't want 10.15 currently.
I have VMware Workstation, but don't want to install the required modifications to make it work, as it seems a little sketchy. I've opted for Oracle Virtualbox 5.xx instead.
My problem is that, I cannot continue my install as I get the following error when using an 10.13.2 ISO (this one is bootable). After following multiple guides, like this one (From the 'Creating VM' section and down): https://tobiwashere.de/2017/10/virtualbox-how-to-create-a-macos-high-sierra-vm-to-run-on-a-mac-host-system/
I get this error: The path /System/Installation/Packages/OSInstall.mpkg appears to be missing or damaged
This is an quite old ISO I've made. I have obtained the 10.13.6 files for the installer too a long time ago, but I can't seem to make this DMG/ISO bootable. It could from a little reseach seem that 10.13.2 might be broken in some way, but I can't seem to figure out how to make a new bootable ISO from the installer files...
Thanks for any help!
https://linustechtips.com/topic/1127972-macos-in-a-vm-problems-installing/
10.15 is really the only version of macOS somewhat designed to be in a VM. Outside of that you might be better off looking at another site to try and help you get this setup. You’re going to have a lot of issues and basically nothing will work out of the box.
What exactly is your goal in trying to VM macOS?
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
I want to test some basic things and in general have a VM ready for some things to try in MacOS. I know performance will be really bad and so on, but my problem is in the actual install process. I suspect it might be my ISO that's broken (or rather, 10.13.2), so the thing I'm really searching for, is help making a bootable ISO for 10.13.6 with the files I have from a previous App Store download.
But thanks for taking the time to answer!
