What kind of internal disk do you have? SATA HDD, SATA SSD, M.2 SATA, M.2 PCIe Gen 3 x4 NVMe?
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
1 minute ago, Tesohh said:
Can you please explain?
There're two types of disk partitioning, older MBR (Master boot record) and newer GPT (GUID partition table). Modern Windows versions use GPT by default so if you've partitioned this disk before it's most likely GPT. Now i'm not sure how prevalent GPT support among Linux distributives but it most likely supported, you'll just need to boot the image as through UEFI, there should be two options in the boot selection screen, one for Legacy and one for UEFI.
Tag or quote me so i see your reply
24 minutes ago, Juular said:
Either your disk are GPT partitioned and you boot MBR image or it's vice versa.
And how do I do that? With the usb drive?
See, when you restart the PC there should be an option to press key to enter boot menu, usually it's F12, F10, F8 or ESC. Now if your image supports UEFI and it's enabled in BIOS (if you've formatted your drive to GPT with Windows then you have it enabled) you can select either legacy boot option or UEFI one, it'll be indicated like that.
What do I need to format? The boot disk or the usb drive?
You need to format the usb drive with Elementary OS image with UEFI mode.
As in this guide (with Rufus), just using Elementary OS image instead of Windows one :
https://www.thomas-krenn.com/en/wiki/Creating_Windows_UEFI_Boot-Stick_in_Windows
Linux DGAF if you use MBR or GPT previously, both partition table formats are supported by parted and fdisk, the disk should still show.
It's more likely that the version 4 kernel doesn't have the drivers for your disk, or there is an oversight in the installer.
Grab a minimal install disk for another distro, check your drive shows with a modern kernel, then either use that or poke Elementary tech support.
It doesn't work with other distros too
I used rufus
