23 minutes ago, Matthewbarkhouse said:
I’m having issues with my triple low end hp27b monitor on iracing. Bad screen tearing and a stutter
Need to cap your fps to the max of the monitor's refresh so it's not going above the free-sync range.
https://linustechtips.com/topic/1127633-hp-27b-freesync-issues/#findComment-13077310
Iracing has a vertical sync option, when clicked it down and cap the range,
the crg9 doesn’t stutter at all at 160fps
https://linustechtips.com/topic/1127633-hp-27b-freesync-issues/#findComment-13077337
Might just be the free-sync implementation.
But you can just cap your fps without V-sync using GPU chill or Framerate Target control in the drivers.
https://linustechtips.com/topic/1127633-hp-27b-freesync-issues/#findComment-13077439
