Hello!
I have an old home built computer that has served my demands relativly well. My old graphic card has broken and is beyond repair from my side Im looking to buy a new one. I was looking to buy a 570 or 580 but im not sure if my Cpu will bottleneck it. Both my PSU and my motherboard are compatlible
Specs:
Cpu: Amd FX 6100 6-core
Gpu: Amd XFX 7800 2gb
Psu: Corshair 650
Ram: Corshair venegance 8gb
Ssd: Kingston 240gb
Motherboard : Asus M5A97
https://linustechtips.com/topic/1127181-compatibility-issues/
Both will be heavily bottlenecked by your CPU.
Edited by LinusTechTipsFanFromDarlo
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/1127181-compatibility-issues/#findComment-13073764
Just now, Hugosjlin said:
What would you recommend me getting in that case? I am concidering upgrading my cpu at some point aswell
Gaming?
زندگی از چراغ
https://linustechtips.com/topic/1127181-compatibility-issues/#findComment-13073779
What do you mean with load requirement? First time i’ve had this problem
there no tasks listed that you do so I assume you don't use the computer in which case there will not be a bottleneck. In order for a bottleneck to exist you need to task the machine with something
https://linustechtips.com/topic/1127181-compatibility-issues/#findComment-13073801
Basic gaming and possibly rust and CodMW
https://linustechtips.com/topic/1127181-compatibility-issues/#findComment-13073815
Yes, only basic games, however I would like to play some more demanding games like Rust and CodMW
I mean an RX 570 or 580 would be a huge upgrade, the issue is that awful CPU. If you were going to get either card, you'd have to pretty much plan to do a platform upgrade immediately to make the card purchase worthwhile.
زندگی از چراغ
https://linustechtips.com/topic/1127181-compatibility-issues/#findComment-13073819
then yeah buy the 570/580. even if it did bottleneck it doesn't matter as you just move the gpu to a newer machine in the future anyway.
not like you have to throw the gpu away when you buy a new machine
https://linustechtips.com/topic/1127181-compatibility-issues/#findComment-13073824
Is there any card that would fit better, that still has good preformance?
https://linustechtips.com/topic/1127181-compatibility-issues/#findComment-13073846
Not really, any GPU made after 2011 will be heavily bottlenecked by your CPU.
زندگی از چراغ
https://linustechtips.com/topic/1127181-compatibility-issues/#findComment-13073854
