Hello guys I have had some very annoying issues with my computer.
After building my computer about 8 months ago I installed windows 8 as its first OS, everything ran fine until about a month later.
The games I where playing (LOL,Tomb raider,Planetside 2 were all pulling 60 fps on my asus 660ti which was overclocked but after some time a strange issue happend where the GPU TDP was going to %40 and the temps were low around 60 c.This caused the games to stutter like mad and be unplayable. The computer screen would go black randomly and then a few days later the computer would not boot just a black screen until I took the gpu out and ran integrated graphics.
I blamed the problem on windows 8 as it was quite new and buggy at the time. I installed windows 7 and everything was fine. After 3 months League Of Legends would randomly stutter like crazy every 5 minutes while getting 60 fps ( it felt like it was about 5) and then it would stop stuttering and the game would feel normal. I put up with this issue as it could just be the game, and now after 4 months or so on this copy of windows 7 I get a random BSOD while LOL launches after it has found a match or the BSOD can happen randomly while switching between windows.
This issue is really annoying and keeps happening could it be my gpu is bad? and if it is how could I send it back thanks.
System Information
Time of this report: 2/8/2014, 14:57:40
       Machine name: HENRY-
   Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7600) (7600.win7_gdr.130318-1532)
           Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
       System Model: System Product Name
               BIOS: BIOS Date: 08/13/13 19:28:07 Ver: 21.04
          Processor: Intel® Core i5-3570K CPU @ 3.40GHz (4 CPUs), ~3.4GHz
             Memory: 4096MB RAM
Available OS Memory: 4038MB RAM
          Page File: 3846MB used, 4227MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: Using System DPI
 System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
      Display Tab 2: No problems found.
        Sound Tab 1: No problems found.
        Sound Tab 2: No problems found.
        Sound Tab 3: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: NVIDIA GeForce GTX 660 Ti
       Manufacturer: NVIDIA
          Chip type: GeForce GTX 660 Ti
           DAC type: Integrated RAMDAC
         Device Key: Enum\PCI\VEN_10DE&DEV_1183&SUBSYS_841E1043&REV_A1
     Display Memory: 3752 MB
   Dedicated Memory: 1989 MB
      Shared Memory: 1763 MB
       Current Mode: 1920 x 1080 (32 bit) (60Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: S22B350
         Monitor Id: SAM08D4
        Native Mode: 1920 x 1080(p) (60.000Hz)
        Output Type: HDMI
        Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.3182 (English)
     Driver Version: 9.18.13.3182
        DDI Version: 10.1
       Driver Model: WDDM 1.1
  Driver Attributes: Final Retail
   Driver Date/Size: 11/15/2013 00:55:24, 18208624 bytes
        WHQL Logo'd: n/a
    WHQL Date Stamp: n/a
  Device Identifier: {D7B71E3E-52C3-11CF-9D7F-13A41CC2C435}
          Vendor ID: 0x10DE
          Device ID: 0x1183
          SubSys ID: 0x841E1043
        Revision ID: 0x00A1
 Driver Strong Name: oem29.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section090:9.18.13.3182:pci\ven_10de&dev_1183
     Rank Of Driver: 00E02001
        Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
https://linustechtips.com/topic/112629-bsod-system-service-exception-help/
I did hear some stories about the 660Ti having some troubles with models that came off the assembly line at different times.  Perhaps downloading the latest drivers and then seeing if that solves the issue would work.
If not, try and find the warranty information from your card and contact them about your issue.
However, like you said problems were happening until you switched to integrated graphics, did you still have any issues after you switched, or did things run fine afterwards?
CPU: Intel Core i5 4670K @ 4.4 GHz Motherboard: MSI Z87 G43 RAM: 8GB Corsair Vengeance 1600MHz GPU: EVGA GeForce GTX 980 Superclocked Case: Bitfenix Ronin
Storage: 120 GB Samsung 840 series SSD, WD Green 2TB PSU: XFX core edition 650W Display(s): ASUS VE228H 21.5IN 1080P Cooling: CM Hyper 212+
Keyboard: Microsoft P.O.S Mouse: Corsair Raptor M40 Sound: Sennheiser PC 330 Headset
While ruining windows 8 I installed beta drivers that still made games stutter then i re installed the non beta drives and still the same problem, then the gpu drivers basically died somehow and then the black screen, I then changed to integrated for the mean time and things were fine.
