I really need help regarding my a gaming PC under 500$ which would offer decent to good performance.
I would also use it for a little bit of 3d rendering but mostly playing games like GTA 5,COD,FORTNITE,etc.
I live in Asia (India to be specific) so if recommended by availability please check.
I would also like to know whether to build a PC now or wait like approx 3-4 months since that is when I would be finishing my semester.It is my decision to decide is what my parents told me so ya..
Like if there is new of some good budget gpu,cpu which will be worth the wait. I will be happy to know that.
https://linustechtips.com/topic/1126097-help-for-pc-build-under-500/
It's very worth it to improve your budget by just a little more, then you can fit a B450 motherboard and possibly a better graphics card like an RX 570
Primary PC:
PSU tier list
How many watts do I need?
What about a build with the Rx 580? Any way to fit that under 500$ or around 40k INR
nope sorry. but for 1080p 60fps i doubt the 570 would disappoint.
Primary PC:
PSU tier list
6 hours ago, Not_Thunder said:
What do u think about this build?
This rig's not that great, only 8GB of ram and the Intel platform locks you into some not so great upgrades in the future.
Or this
This one has a monitor in the build so it sort of changes the whole pricinf structure.
For 50k Rp:
You can fit a 1660 as well as a 4C/8T CPU instead of 4C/4T, so it really affords you a lot more performance I also squeezed in that better motherboard.
Primary PC:
PSU tier list
For 50k Rp:
Ya this is good but I have been given a 50k-55k budget to build the full setup??.
So I have been hunting since a month haven't found anything that fits my need like ; I don't know whether to go with first gen amd since many reviewers say that it isn't a good option. Also I wanna use Unity3d developer to make games so that should be fulfilled too.
I am really confused at the moment ???
It is a good option.
Primary PC:
PSU tier list
