I live in the UK and currently my house's networking consists of an ISP provided modem/router/switch, I'm wanting to improve our networking but I can't find a modem (not modem router) that is cable connected and that supports my ISP (I'm with Virgin Media if this helps) any ideas for modems I could use? I'm not sure if the Netgear CM series are compatible with my ISP as It seems to be a US modem ? any ideas will help
By cable I mean coaxial but you guys probably already know that though
https://linustechtips.com/topic/1125700-cable-modem-help/
I would check your ISP's website or maybe call them and see if they have a list somewhere of compatible modems. Some should theoretically be compatible based on connectors but your ISP won't officially support it and may give you a hard time about it if there are ever any issues even if the modem is not the issue
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Pulsar)
CPU: Ryzen 7 5800X MOBO: MSI MEG X570 Unify RAM: Corsair Dominator Platinum RG(4x8gb) 3200Mhz 16-16-16-32 GPU: EVGA GTX 1080 FTW ACX 3.0 Cooler: Noctua NH-U12S Chromax (LTT Edition) Storage: Intel 6000p 128gb boot drive, Intel 665p 1tb (x2), Samsung 850 EVO 1tb, Case: Phanteks Enthoo Pro M Tempered Glass PSU: EVGA SupeNOVA G1+ 750W OS: Windows 10 Pro 64 bit
FreeNAS Server (The Vault)
CPU: Xeon E5-2603 v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000Mhz 16-18-18-38 GPU: EVGA GT 710 Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 x2 for boot, x16 in RAIDZ for storage, Seagate Ironwolf 2tb (Striped will be a steam cache) Case: Phanteks Enthoo Pro Tempered Glass PSU: Corsair CX750 750W
https://linustechtips.com/topic/1125700-cable-modem-help/#findComment-13062329
