15 hours ago, manwithsomeham said:
Would a T430 be able to support newer processors such as a AMD Ryzen 5 1600?
I dont think so. you can replace it with 3rd gen cpu from intel though.
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1125070-t430-cpu-replacement/#findComment-13056975
15 hours ago, TheGlenlivet said:
Laptop??  No.  Laptops are ALMOST ALWAYS soldered.
In this case, the CPU is replaceable
check around 3:20 mark
here is the list of CPU you can use to upgrade it with
http://www.cpu-world.com/Sockets/Socket G2 (rPGA988B).html
CURRENT PC SPECS
https://linustechtips.com/topic/1125070-t430-cpu-replacement/#findComment-13056977
Would that be any 3rd gen i5 or i7?
http://www.cpu-world.com/Sockets/Socket G2 (rPGA988B).html here's the list of the compatible CPU for you. check for whatever spec you need.
CURRENT PC SPECS
https://linustechtips.com/topic/1125070-t430-cpu-replacement/#findComment-13056983
Welp, there is the ALMOST I mentioned huh?  hehe
Looking at the video it does look like the CPU is a Ryzen with the pins on the bottom of the processor, but then checking the specs it says it's only intel.
A 3520M is the highest powered CPU listed.  Not sure if they all have the same motherboard and power delivery.
https://linustechtips.com/topic/1125070-t430-cpu-replacement/#findComment-13056986
id personally recommend
i7–3840QM(4c/8t 2.8-3.8ghz) and or i7–3632QM(4c/8t 2.2-3.2Ghz)
the first one is 45W tdp and the second one is a 35W tdp
CURRENT PC SPECS
https://linustechtips.com/topic/1125070-t430-cpu-replacement/#findComment-13056988
