Basically, I have a GTX 1060 6GB which apparently is supposed to be a quite good card, and my Unigine Heaven Benchmarking stays at a stuttery 65 FPS at max settings, but every time I play a game, even on Medium settings on Destiny 2 for example, my FPS is very inconsistent. Sometimes it will run at a Fluid 60-70 FPS on Highest, then other times it will run at 20 FPS on Medium. It also translates into other games. Games like The Binding of Isaac: Rebirth, a very un-graphic intensive game, will stutter and freeze up constantly. I have an AMD Athlon II 645 Processor at 3.10 GHz, along with 8 GB of gaming RAM as well. I am on Windows 7. I am getting tired of being unable to play games because even on Medium they are a stuttery and laggy mess. Please help me.
https://linustechtips.com/topic/1124397-trouble-with-lag/
Pretty sure you are severely CPU bottlenecking. Im guessing you look at CPU usage during gamings its pinned at 100%, which is causing the stuttering as it cant keep up with the GPU.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/1124397-trouble-with-lag/#findComment-13051834
Holy cow thats a 10 yearold cpu. Even a gt 1030 gets bottlenecked by that.
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1124397-trouble-with-lag/#findComment-13051837
Unless you plan to upgrade that cpu, then you are kind of out of luck my friend.
If you do, how much do you plan to spend?
CURRENT PC SPECS
https://linustechtips.com/topic/1124397-trouble-with-lag/#findComment-13051845
Have you tried buying a used pc before? I think almost anything is better than that athlon. There might be some used prebuilts that is actually quite decent that doesnt bottleneck that GPU. With that budget, you cant really buy a new pc components. So ye, if you managed to find something used at around your budget, that great. Ebay is a great place to start but ask the others here about what you see.
CURRENT PC SPECS
https://linustechtips.com/topic/1124397-trouble-with-lag/#findComment-13051868
Microcenter near me was selling Ryzen 2700x for $129.99 and $30 off any mobo. 16GB of RAM for $64.99. You could get a system thats twice the RAM and about 10x+ faster CPU (way faster than even a 8350 by more than 100%) for <$300, but i understand youre on a budget and i dont know if you have a microcenter near you. You are on a pretty dead platform ideally you need to get off.
https://linustechtips.com/topic/1124397-trouble-with-lag/#findComment-13051890
