I recently bought modern warfare and have been have issues with a stable at least 60 fps on low-medium settings on 1080p, I'm noticing frequent frame drops. I have a 144hz 1440p monitor, I'd like to play at 1440p 60 fps or at least close to 144hz 1080p.
I don't know if its hardware or software issue. I'm up to date on my drivers
  • CPU
    i7-2600k
  • Motherboard
    ASUS P8H61-M EVO
  • RAM
    8 GB KINGSTON 1333 MHz
  • GPU
    MSI GTX 1060 6GB GAMINGX
  • Storage
    HYPERX SAVAGE 240GB SSD, 4x 320 GB HDD (RAID 0)
  • PSU
    EVGA 500W 80+ BRONZE
  • Cooling
    CORSAIR H115i
https://linustechtips.com/topic/1124388-modern-warfare-fps-problem/
Isnt 1060 a 1080p gpu? Also, i think the gpu got bottlenecked by the cpu.
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
yes but I dont have issues playing games at 1440p 60hz if I play fps games I drop down to 1080p for higher fps, also planned on upgrading in the future. also thanks for the response. when I was upgrading my main monitor I wanted more than just 1080p 144hz, I wanted to upgrade to 1440p and my videos look better :)
Well i used to own a 1060 and id say even without bottlenecking, some games struggles at 1080p. Heck even the division 2 struggled to maintain 60 fps. Even fallout 4 has its drops. At high. So ye, i think pushing for a 1440p at 60 fps is a bit too much. Especially with that cpu that bottlenecked the gpu.
Edited by Martin2132
Needs additional info
CURRENT PC SPECS
ok thank you for the response, i'll have to work on my hardware then :)
