Hello LTT
Me and my friend decided to start mining. we have a 7870 and a 5870.
We use cgminer and ypool.net as my pool.
But we can not get any decent kh/s we got 100kh/s when it ran best. that was on both cards. i think it was around 70kh/s on the 7870 and 30kh/s on the 5870.
What are we doing wrong. i can´t remember the exact numbers in the .bat file but i believe it was
setx GPU_MAX_ALLOC_PERCENT 100
cgminer --scrypt -o (myhost/pool) -u (username).(worker) -p x --thread-concurrency 7400 -I 13 -g 2 -w 256 --lookup-gap 2
When i turn up the intensity up over 18 the driver crashes
When i turn thread-concurrency up it results in lower kh/s
what am i doing wrong. i have been mining protoshares on my GTX 780 for about a week now and that was not nearly as hard to setup
We use cgminer v. 3.7.2
Best regards
Jakob
CPU: I7 4790K GPU: Manli GTX 980 Mobo: Asus Gryphon z97 RAM: kingston Hyper x fury 16GB 1866mhz PSU: EVGA supernova 750W G2 SSD: Samsung 840 evo 500GB HDD: WD Black 3TB Case: Parvum s2.0 Fans: Noiseblocker E-loop 800rpm Cooling: Custom water cooling
https://linustechtips.com/topic/112437-cgminer-problems/
Hello LTT
Best regards
Jakob
Don't use CGMiner.
Use SGMiner
Try switching -g 2 to -g 1. SGMiner uses the same settings as CGMiner, except you should remove the --scrypt as it is forced.
SGMiner is an updated version of CGMiner for Scrypt and GPU mining.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/112437-cgminer-problems/#findComment-1503411
Don't use CGMiner.
Use SGMiner
I cant even get SGminer to launch
With the same inputs
Try replacing
 with
-shaders 1280
Also,
setx gpu_use_sync_objects 1
might help
nope did not work
These to card does not work with me
https://linustechtips.com/topic/112437-cgminer-problems/#findComment-1504935
nope did not work
Using the same modifications I suggested above, try -w 128. You could also muck about with the intensity a bit; try 11 and 18 and see what happens.
Pilates
https://linustechtips.com/topic/112437-cgminer-problems/#findComment-1505011
Going to try that tomorrow then.
https://linustechtips.com/topic/112437-cgminer-problems/#findComment-1505144
