Replace Heatsink Fan
Go to solution Solved by -rascal-,
14 minutes ago, Meridian said:
Hey there.
I want to replace my current heatsink fan with a fan with RGB. My current cooler is the Arctic Freezer 33 Esports one with an Arctic BioniX F120 on it.
Now my question: Do I have to use a specific fan with specific static pressure, RPM etc. or does any fan work, as long as it supports PWM?
And I'd appreciate any recommendations! :D
Thanks in advance, Meridian.
It the fan is not proprietary, uses standard 120mm fan dimensions, you should be able to just do a simply fan swap.
The spec of the fan does not affect the heatsink itself, but a higher static pressure fan usually results in better cooling performance through a heatsink, radiator, etc.
RPM is just the speed range of the fan, but somewhat does hand-in-hand with static pressure, and fan noise.
You don't *need* a PWM fan, but it will give you MUCH control over the fan speed.
Hey there.
Edit: And would a Corsair ML120 Pro work for this heatsink?
Edited by Meridian
Written in topic
https://linustechtips.com/topic/1123985-replace-heatsink-fan/
Hey there.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1123985-replace-heatsink-fan/#findComment-13049186
Yes, as far as I can tell it's a generic 120mm fan. Nothing fancy or unusual. Thanks for your answer! :D
https://linustechtips.com/topic/1123985-replace-heatsink-fan/#findComment-13049268
