My low fps problem
Go to solution Solved by MartinKweh,
15 hours ago, NoobGandalf said:
Actually it worked only for minecraft. On overwatch and csgo I still stays at 60 fps.
check if you have the frame limit on. i think overwatch has it. CSgo has it as well i think. check nvidia settings. there might be something there such as power saving and vsync to all.
I just build my first pc the specs
Corsair vengeance pro 32gb 3200 hmz
Evga 2080 super
I7 9700k
Asus Z390a
Corsair H115i RGB
Corsair 550x Bronze certified
West digital 500gb ssd
Seagate 2tb hhd
And a Corsair obsidian case
My problem is that my games get really low fps. For example Minecraft on max graphics 32 chunks, and no mods runs barely 60 fps. Overwatch also barely gets up to 60 fps on max graphics.
Does anybody have a solution for that.
As I said thats my first build so I'm not that advanced.
https://linustechtips.com/topic/1123453-my-low-fps-problem/
is the power plan on energy saving?
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1123453-my-low-fps-problem/#findComment-13044610
is Vsync or frame limmiter on? sometimes those affects FPS too.
CURRENT PC SPECS
https://linustechtips.com/topic/1123453-my-low-fps-problem/#findComment-13044626
Just now, NoobGandalf said:
That actually worked, thanks. But what does the vsync affect.
vsync cap your fps to your monitor refresh rate to prevent screen tearing when fps exceeding your monitor refresh rate. For example, if you have 60 hz monitor and you enable vsync than it will cap to 60 fps
https://linustechtips.com/topic/1123453-my-low-fps-problem/#findComment-13044645
it makes the frame rate match the refresh rate of the monitor. mainly to reduce screen tearing.
CURRENT PC SPECS
https://linustechtips.com/topic/1123453-my-low-fps-problem/#findComment-13044648
CURRENT PC SPECS
https://linustechtips.com/topic/1123453-my-low-fps-problem/#findComment-13044673
