I don't know if this is the right place to post this, but I really need help. I accidentally did something that made every jar file turn into a WinRAR archive, and I don't know how to get it back to normal. I have tried to click "open with" and find some sort of java program, but I can't find any. I have Windows 8.1
Just to show you an example, here is a picture of the .minecraft folder:
https://linustechtips.com/topic/112337-need-help-fast-changed-file-types/
When you click open with, press on BROWSE. When the window shows up, go to C:\Windows\System32 and find Jave.exe and select it. Now make it the default program.
@Godcer You need to do this ^.
you have just associated the file with winrar
here's a video of a robot telling you how to do it
The only java file I can find in C:\Windows\System32 is JavaScriptCollectionAgent.dll and I doubt that is the right one.(Type: Application extension)
You need to download Java Runtime Enviroment and search for that in Program Files. I don't know how this works with Win8 but try to enable "show known extensions" and check that file is still .jar and not .rar.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
