Hi, so this is my first time assembling a pc. Everything worked fine except that I tried running gta. My temps went up to 98 on the cpu. The GPU was fine so I replaced the thermal paste because maybe it was that but no success there. I've plugged my AIO into the AIO_PUMP header on my motherboard. But every time I boot the system it says "cpu fan error" what should I do?
https://linustechtips.com/topic/1122589-h150i-pro-not-working/
The cpu_fan error indicates that there's low or no fan rpm detected from the cpu_fan header. The error message can usually be disabled if you plan to not use that header.
https://linustechtips.com/topic/1122589-h150i-pro-not-working/#findComment-13039097
