So I completed my build today and I'm facing a ridiculous problem. Whenever I restart my PC from BIOS Setup or Windows it doesn't POST anything. Sometimes it boots but doesn't POST (I guessed it by watching ram's rgb profile changed which I made).
But if I completely shut it down and after a few seconds turn it on, it posts and boots perfectly. And all the components just works fine. I ran some games and didn't notice any problems. It's not a ram problem I am sure. I tested both rams individually and both of them were working perfectly. But none of them were able to reboot my pc. So I guess the problem is somewhere else.
I also reset BIOS using the button. It didn't help either.
PLEASE HELP,
My rig:
Mobo: MSI MPG X570 GAMING EDGE
Cpu: RYZEN 7 3700X
Ram: G. SKILL TRIDENT Z RGB 8X2 3200MHZ
Gpu: SAPPHIRE NITRO+ RX 5700 XT 8G
Ssd: Samsung 970 evo plus 250 GB
Psu: Cooler master mwe 750w gold
https://linustechtips.com/topic/1119552-pc-doesnt-reboot-help/
