oof, that's not just the fan attachment but the fan assembly itself. I would start by taking the plastic fan bracket off and checking for damaged parts
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1118279-gpu-fan-dropped/#findComment-13003736
Remove busted fan
Zip-tie a 120mm fan to GPU shroud and plug into motherboard for power
Set speed in BIOS
Game on
(last resort, or first resort if looks don't matter to you as I am all for DIY and saving money when possible)
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1118279-gpu-fan-dropped/#findComment-13003868
10 minutes ago, Corrupt_Liberty said:
i live in tunisia, and i can't buy from elsewhere .. :(
https://linustechtips.com/topic/1118279-gpu-fan-dropped/#findComment-13003869
Just now, Tristerin said:
Remove busted fan
Set speed in BIOS
Game on
aah good idea, but now or later i need to fix the real fan place! thanks ❤️
https://linustechtips.com/topic/1118279-gpu-fan-dropped/#findComment-13003873
easy fix, but a last resort.  Id prefer to have the card look good so for a certain amount Id fix it (like $10) but if not, just DIY and move on, its part of the "buying used" process (I have 2 used GPUs in use right now, so I understand why buying used is good :) )
https://linustechtips.com/topic/1118279-gpu-fan-dropped/#findComment-13003879
thanks ❤️
https://linustechtips.com/topic/1118279-gpu-fan-dropped/#findComment-13007489
