System crashes on heavy load
Go to solution Solved by nextg3n,
sounds to me like a psu issue... when at max load it cant handle it anymore and gives out...
My system is getting crashed while gaming or benchmarking, but runs without any problem for whole day on normal usage
Troubleshooting steps:
  1. Operating System: Tried on 2 different OS Ubuntu 18.04 and Windows 10 (separately installed on 2 different SSDs) but problem persists hence its not an OS issue
  2. Memory: I have a 2 RAM stick each with 8gb, With single RAM stick (anyone) benchmark or game runs a bit longer before crashing as compared to both RAM stick when configured in dual channel mode
  3. Overheating: While running heaven benchmark or game (Far cry 5) stats of CPU/GPU are GPU: 67 °c (max)  Usage 99% (avg)CPU: 50 °c (avg. per cores). Hence I believe it’s not a CPU/ GPU overheating issue
  4. Checked SSD health on Western Digital SSD Dashboard it is also ok
My system configuration
PC part picker
Please note there are some components that I couldn’t find on PC partpicker hence some components might be missing but below is the comprehensive list of all components in my PC
CPU: Intel Core i3-8100 3.6 GHz [4c / 4t]
GPU: Zotac GeForce GTX 1050 Ti 4 GB OC Edition
Motherboard: ASRock B360M Pro4 Micro ATX
RAM: Corsair Vengeance LPX 8 GB DDR4-2400 (x2)
PSU: Corsair VS 450 W 80+
Hard disk: Seagate Barracuda 2 TB 3.5" 7200RPM + Western Digital Green 240 GB 2.5" Solid State Drive (x2)
Optical drive: Asus DRW-24D5MT DVD/CD Writer
Cabinet: Corsair SPEC-01 + Circle Stay Cool CG-12 120MM Red LED Case Cabinet Fan (back)
Monitor: LG 22MP68VQ-P 21.5" 1920x1080 60 Hz Monitor + BenQ GW2270HM 21.5 inch FHD(1080p) Monitor
UPS: APC BX1100C-IN 1100VA 230V Back UPS
System ran without any problem for 1 year but from past week I am getting this issue
https://linustechtips.com/topic/1118103-system-crashes-on-heavy-load/
1 minute ago, Atinesh said:
Can you suggest me any good PSU for my PC with enough capability for future upgrades
id suggest to stcik with corsair but go for something  with more capacity id say around 600W should be alright considering future upgrades...
Some EU input to Canadian IT :D
Just now, nextg3n said:
thats decent but just to be safe borrow some firends or etc psu and see if it makes a difference otherwise ur out a 120 bucks...for nothing...
I also need to update my GPU in few weeks, so even if it doesn't solves my problem I need better PSU.
