So i just got a new case and put all my old pc parts in it with a new graphics card the 1060. I get no signal when i turn it on exept the very first time when i booted it it gave me my mobo bios. Now im not getting anything. My parts are z68 micro sli i52500 16 gb ram 1060
650 watt psu. I did switch from a rx480 to a 1060 i didnt unistall any drivers but i dont have the old gpu idk if thats the issue but my mobo has no onbourd graphics from what i can see and i dont know what to do :(
https://linustechtips.com/topic/1117679-no-signal-help-please/
2 minutes ago, Gregg said:
It only showed me it once the t time now it doesnt do anything no signal to monitor but all the lights turn on
Reset the BIOS on the mobo? Usually there is a switch or a button or perhaps you have to pull the BIOS battery for it to reset...
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1117679-no-signal-help-please/#findComment-12999228
Also try another port or cable.  So the monitor is orange Im assuming because you said it lights up ?  So it lights up just doesn't show ?.  Also you can try another PCI slot if that is not too much trouble.  Just some quick TS I can think of right now.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1117679-no-signal-help-please/#findComment-12999272
