Logitech G Pro Replacement Cable
Solved by SupaKomputa,
You can straight it out with a hammer. do it lightly.
the internals should be intact since it's not ripped apart.
It seems that the port doesn't make contact due to the bent.
can you plug the other end to the headset?
if yes, just whack the broken end and replace it with a new plug.
michaelb198 ·
Posted in Peripherals0 -
errorcode123_dindin1 ·
Posted in Graphics Cards2 -
Packhunter ·
Posted in Graphics Cards3 -
11
4
VirusDumb ·
Posted in Programming0 -
Jayraj ·
Posted in Power Supplies4 -
Airmack ·
Posted in Graphics Cards1
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
