Enough power?
Go to solution Solved by TheGlenlivet,
Plenty.
550 watts is good, hopefully you're not buying a green label CX or a VS
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1114491-enough-power/#findComment-12973415
-moved to PSUs section-
That should be fine for power assuming it's a quality unit.
https://linustechtips.com/topic/1114491-enough-power/#findComment-12973420
