Graphic Card Issue
Go to solution Solved by Rani,
I believe everything is fine now, pc has been running for over an hour now with no crashes. The fix was most likely opening up the gpu and changing the thermal paste, or rolling back the driver. Either way, everything seems to be fine.
Thank you for all the help!!
Hello,
Recently my games have been crashing in a similar fashion. It starts with a semi checkered pattern and both my screens go black then turn back on with the game crashed. With destiny 2 it gives me a pop-up saying  "Graphics runtime detected a crash or loss of device." I have uninstalled the drivers using DDU and reinstalled the lasted drivers to no avail. This wasn't happening at all yesterday and only this morning my only suspension is the most recent nvidia update. Any recommendations. lowered the frequency by 100 and checked the pcie pins. End result was still crashing. I had originally posted this on troubleshooting
Ryzen 5 2600
gtx 1060 6gb
gigabyte b350
https://linustechtips.com/topic/1114230-graphic-card-issue/
that already means something's gone wrong on the hardware side. I doubt it's a software issue
Desktop benching:
https://linustechtips.com/topic/1114230-graphic-card-issue/#findComment-12971034
ehhhh.......
thats only if there wasn't any software running , like if it was checkered in the bios before the os or anything loaded
https://linustechtips.com/topic/1114230-graphic-card-issue/#findComment-12971104
41 minutes ago, Rani said:
What kind of hardware issue would happen if I haven't touched anything in my pc?
the GPU itself dying, or the video memory on the card
16 minutes ago, emosun said:
ehhhh.......
without running software the GPU locks itself to idle clock, which is more stable than base clock that's used when the driver loads in.
Desktop benching:
https://linustechtips.com/topic/1114230-graphic-card-issue/#findComment-12971134
yeah so if it artifacts with no software running then it's a hardware problem. once you add software then software becomes another link in the chain. which is why I can make any gpu artifact just throwing a car around in beam ng too quickly.
that being said he would have artifacts in video and immediately in any 3d application if the vram had a problem as that's where artifacts manifest.
https://linustechtips.com/topic/1114230-graphic-card-issue/#findComment-12971143
1 hour ago, emosun said:
why was the driver updated if the machine wasnt having problems
Because that seems like a logical thing to do.
I would indeed suggest to try to install an older driver, perhaps multiple times if it doesn't work the first time.
Just to be sure, are the temperatures on the card okay? (also VRAM temperatures and such (if they are visible on a program like HWiNFO64))
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
https://linustechtips.com/topic/1114230-graphic-card-issue/#findComment-12971175
4 hours ago, Rani said:
While idle the temp is 49c highest while running a game was 70c. Im using msi afterburner.
That should be fine. 49c idle seems a bit high, but shouldn't cause these issues.
4 hours ago, emosun said:
name a reason to update a driver that doesn't have a problem
New features, improved performance in games, because manufacturers/developers always want us to update every single thing in existence, etc.
https://linustechtips.com/topic/1114230-graphic-card-issue/#findComment-12971637
implying there was something wrong with the previous driver , aka fixing issues.
they had no issue until the update meaning you only update when you have an issue.
https://linustechtips.com/topic/1114230-graphic-card-issue/#findComment-12972777
https://linustechtips.com/topic/1114230-graphic-card-issue/#findComment-12973143
