Hello guys! First post here, thanks for having me.
I really need to upgrade my rig and just bought a reasonably priced RTX 2080 Ti with 11gb ram from Zotac (ZT-T20810F-10P), could not miss that opportunity.
Now I need to figure out if my current configuration is up to use this GPU, if I need to change anything else to avoid bottlenecks,
This is my current config:
  • Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
  • Kingston HyperX FURY 8GB 1866MHz DDR3 CL10 DIMM (KHX1866C10D3/8G) x2, total 16GB
  • Z97X-Gaming 7 motherboard
Do you think I need to change anything? I wish I could still use the CPU but not sure if both RAM and motherboard would create bottlenecks or even if its compatible with the GPU I've just bought.
Thanks!
https://linustechtips.com/topic/1114031-personal-pc-upgrade-help/
Depends on the title.  Some titles demand more cores than you have, so overclocking the CPU will give you more headroom on that GPU in both scenarios (if it needs more cores or not)
Id first see how it works together, first, however since you already have it to then make the decision if you like the results of your upgrade.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
It depends.
  • What games are you playing? Do they need more CPU or more GPU power?
  • What resolution is your monitor? FHD will need more CPU power and 4K more GPU power.
  • What frame rate is your monitor? 144Hz in any modern game would be a struggle with a 4790K.
The RAM and motherboard won't be a bottleneck, unless you have scientific calculations that need really high RAM speed.
My boring Github   /人◕ ‿‿ ◕人\
There are plenty of circumstances where the 4790K pairs well with a 2080 ti, all that's left is to see whether or not your standards are met by its performance
Primary PC:
PSU tier list
How many watts do I need?
Thanks!
Depends on ur monitor.
if ur aiming for high FPS figures ull need a new CPU.
If ur aiming sub 120 though .., like 4k resolutions, ur fine.
Would suggest you OC that CPU though. 4.5ghz should be an easy target.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
Wow thanks a lot guys! So many responses on such a short time, this place is really awesome.
Since I don't play very often on my machine, I really want to prepare it for the upcoming Red Dead Redemption II and plan to start on VR early next year. For now I mainly use it for video editing, 3d modeling an a bit of gaming (GTA V, CS-GO, Just Cause 4).
So I think the CPU is OK then, just a little OC and it should be fine since I have an Intel water cooling system for it. I was mainly worried about the slow RAM and old motherboard.
I forgot to say: I use it on a LG 55SM8600 4K TV for playing games...
Do you think the current motherboard should be fine? No need for a faster PCI connection or anything else?
Thanks again!
It is already PCIe 3.0. PCIe 4.0 is only available with Ryzen 3 and not even supported by your GPU. Even if it was supported, it wouldn't need that much bandwidth. If you want high speed storage, then you might need a new motherboard, but you really don't need more than 1 GB/s (2x PCIe 2, your motherboards M.2 connection) for game loading.
Thanks mate. I have a dual SSD as RAID0 so that is enough speed for me.
This information set my mind at ease, I shall have a great graphics performance update since I am coming from a GTX 970.
Can wait to see those RTX effects :)
Thanks!
If you play in 4k resolution, there should not be that much of a bottleneck. The GPU will be really stressed so the CPU won't be an issue. Nevertheless, you should try to OC the I7 a little bit more, if you can. As @SolarNova said, 4.5GHz seems like a good number.
Be sure that the thermal paste is not to old for temperature issues.
Good luck.
