Hi,
Can someone point me to where I can get cables/adapters for me to be able to connect my
Sapphire Nitro+ 5700 XT rgb headers
to my Asus Strix x470
I just bought both of them this month and I'm quite new to this ARGB thing.
I got this cable with the motherboard but it only connects to the GPU end.
https://linustechtips.com/topic/1113877-need-help-with-argb-cables/
  • 3 months later...
  • 4 months later...
On 2/9/2020 at 1:15 AM, NachoN7 said:
Hi, did you get an answer? I have a similar board and the same graphics card and I can't figure out how to connect it. Thank you
Hey,
Sorry for the late reply. Not sure if this will still be helpful to you but I'm posting anyway for anyone who comes across this post.
I bought these from AliExpress:
https://www.aliexpress.com/item/32972982062.html?spm=a2g0s.12269583.0.0.5cd378a2qDCOst
Unfortunately it took a while for me to get it due to the pandemic (6 months), that's why I'm only replying now.
Anyway, the good thing is that it worked! Just make sure to connect it to the 3-pin argb header on your motherboard and set Sapphire Trixx to 'External' control for the lighting.
