This is my first pc build and I got the corsair h100i pro aio cooler. I attached the fans as instructed to pull air in and I had two extra case fans that I slapped on the back bc why not. But the air vent and clearance where the air intake is, is rather limited in the NZXT h510 case. Would I be better off without the case fans pushing air and a bigger space for intake or does the limited space air intake not matter that much??? I have attached imagines to hopefully make it easier to see what I'm talking about. Thanks in advance for all advice!
https://linustechtips.com/topic/1113829-radiator-fan-overkill/
The key thing is if youre looking at the sticker the air flow is away from you,
and i would like to be sure that you have the fans facing the same direction, but usually one side of fans is enough
PC: Alienware 15 R3  Cpu: 7700hq  GPu : 1070 OC   Display: 1080p IPS Gsync panel 60hz  Storage: 970 evo 250 gb / 970 evo plus 500gb
Audio: Sennheiser HD 6xx  DAC: Schiit Modi 3E Amp: Schiit Magni Heresy
https://linustechtips.com/topic/1113829-radiator-fan-overkill/#findComment-12967671
2 minutes ago, RxLew said:
Here is the front and back correct me if I'm wrong but they are blowing air in the same direction, right?
Yep, you'e good, i just wanted to make sure
so if your radiator mounts just fine, then you have nothing to worry about
https://linustechtips.com/topic/1113829-radiator-fan-overkill/#findComment-12967718
Yes, they're facing the same direction but exhausting out of the case. That's not taking advantage of the case's fan filters.
You should flip the fans around.
https://linustechtips.com/topic/1113829-radiator-fan-overkill/#findComment-12967746
Thanks for the advice! And I did end up switching it around to make it an intake!
https://linustechtips.com/topic/1113829-radiator-fan-overkill/#findComment-12968005
