Hello,
I would like to find out if its possible to modify the firmware of a smart phone in one of two ways: 1) changing a phone's identify essentially fooling it into thinking is a superior model, for example, making a Huawei P20 Lite think its the pro version OR 2) forcibly upgrading the current android software to a newer version, in my case, from Android 9.0 / EMUI 9.1 to Android 10 / EMUI 10.  I've tried to do research and find sources to assist me but I haven't found anything.
My reasoning for option one is that I would be able to download the official EMUI upgrade a lot sooner and I imagine it would be the safer option. However, if that fails, I guess option two would omit the in-between hassles and upgrade it directly to the newer EMUI / Android version.
I am extremely eager to get the universal dark mode on my phone and unfortunately, these third party dark themes just aren't working for me.
Any advise is greatly appreciated :)
Regards,
leviathan1701
"That is from an obscure language known as French- Mr. Data, the french language for centuries on Earth represented civilisation- But surely sir... - I suggest you drop it Mr. Data" - ST TNG
https://linustechtips.com/topic/1112529-huawei-p20-lite-force-firmware-upgrade/
Yes but you won't get updates, this is due to phones having different sets of components. You are out of luck, you can try rooting but most method of rooting a Huawei phones are very sketchy.
-https://www.gsmarena.com/compare.php3?idPhone1=9098&idPhone2=9106
