Need Help for PSU
Solved by mxk,
Just now, Will23r said:Thank You for the Help. Roughly what would you say the watts requirements of this system is?
I was editing my comment but actually,
click the yellow text under my comment box that says PSU Tier List and look in the "Budget" tier. Any of those power supplies are good for your range.
Just stick to around 450-550w (550 at the most), you don't need a shitload of power contrary to popular belief
