Is there anywhere that still sells a new white xbox controller? if not i'll just buy the black one. And where can i get the wireless one for cheapest? I want to use newegg's price match thingy.
CPU: Intel Core i7 2600k | Mootherboard: ASUS P8z68v-Pro | GPU: EVGA GTX780Ti 3GB | RAM: Kingston HyperX Genesis 8GB (4GBx2) 1600mhz | PSU: Corsair AX760 | STORAGE: Samsung 840 Pro 512GB | COOLER: Noctua NH-C14 | CASE: Fractal Design Define R4 Pearl Black | Operating SystemWindows 7 Professional 64-bit |
https://linustechtips.com/topic/111216-white-xbox-controller/
For which Xbox?
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/111216-white-xbox-controller/#findComment-1486593
For which Xbox?
windows
https://linustechtips.com/topic/111216-white-xbox-controller/#findComment-1486603
For which Xbox?
It'd  be great to know, Original XBox, XBox 360, or XB1.
My n00Build http://pcpartpicker.com/user/NameOfNoInterest/saved/
Do you really expect me to know things?
$25.67/$~2500 (Price changes hourly..) I'm 1/100th of the way there!
https://linustechtips.com/topic/111216-white-xbox-controller/#findComment-1486605
windows
Did you really just say windows...
https://linustechtips.com/topic/111216-white-xbox-controller/#findComment-1486608
windows
Well like Which controller design?
Hope I could help!
https://linustechtips.com/topic/111216-white-xbox-controller/#findComment-1486611
the 360 design.
https://linustechtips.com/topic/111216-white-xbox-controller/#findComment-1486617
the 360 design.
Try searching Amazon.com and Ebay.com
https://linustechtips.com/topic/111216-white-xbox-controller/#findComment-1486620
This is kinda off topic but razer's sabertooth controller is great, you should check it out :D
https://linustechtips.com/topic/111216-white-xbox-controller/#findComment-1488502
I would say get the Wired one, It is a lot let hassle since MS doesn't sell the official dongle by itself anymore.
Delltopia
Case & Mobo: Stock Dell Optiplex 7010, CPU: i5 3470, RAM: 16gb 1333 DDR3 (1x8gb Corsair Vengence, 2x4gb Random), GPU: Diamond Radeon HD 7970,
PSU: EVGA GQ 650W, SSD: Kingston v300 128gb (OS), HDD: 700gb Seagate 7200rpm (Storage)
https://linustechtips.com/topic/111216-white-xbox-controller/#findComment-1488571
