Use the AIO as intake. Or else your AIO will be using the hot air from your GPU to exhaust out the case, raising your CPU temps. Has been tested multiple times by LTT, also GN and others.
Join HWBot or OCN
#1 3DM Fire Strike Ultra score in the world.
#2 3DM Time Spy Extreme score in the world.
#3 3DM Fire Strike Extreme score in the world.
#7 3DM Sky Diver score in the world.
#8 3DM Fire Strike score in the world.
#12 3DM Time Spy score in the world.
All scores obtained with 8600K + 1x 1070Ti. Links in bio
Ok thanks. For my case, should the radiator be on top or side?
Front. Do not put it on top. Watch this video if you are still confused.
Join HWBot or OCN
