Fan advice request
3 minutes ago, Hades101 said:Sorry if i should have had this info in the original post, still new to posting in forums. Noise not really an issue except at low RPM. gonna probably stick with with the stock wraith prism cooler, looking at these in particular Because its a very highly reviewed brand, there available here in New Zealand for a reasonable price and they aren't RGB. and yes I am open to other options but i do like the overall look of these.
If you like the aesthetic of these fans in particular and aren't aiming for very low noise, you might as well get the High-Speed ones or whichever is cheaper.
They're pretty well priced too so I'm not seeing anything with substantially better value.
The case comes with 2 stock case fans so I recommend trying them out rear / top exhaust along with a pair of 140mm PW2's for front intake first. If you think they're too noisy, you can replace them with 120mm PW2's later on. If you're doing it primarily for the fan aesthetic, you could just get all PW2's now.
