Folding@home Web control issues
Go to solution Solved by Lenovo1984,
16 hours ago, keenhydra said:
Chrome, latest update.
Switched to edge just for the web control and it's working fine for now.
I would just use Edge for it. I have always had issues with F@H Web Control on Chrome.
So I've started Folding@Home this month like I do every year in October, and everything worked fine all day with a complete Work Unit within a few hours.
Now I went away for an hour or two to run some errands and figured I'd put my pc to its full use and turn the dial to full until I would be back.
Well I'm back now and it seems the Web Control client froze.
A short summary of what's going on:
Not displaying Identity
No longer controling the power used by F@H
Constant "Reloading" of the page, flashing every other second.
Little black bar in the bottom saying "Waiting for My IP Address"
Next to these issues, the F@H process is stuck at full power and I can't really seem to find a way to turn it back down aside from stopping the process altogether in task manager.
I hope anyone here has had this happen to them and has found a solution to this problem. I run an AMD system so it's getting pretty toasty in here..
Thanks!
https://linustechtips.com/topic/1109648-foldinghome-web-control-issues/
Thanks!
In your taskbar is a Folding at Home icon, right-click on it and select "Advanced Control" from there you should be able to adjust the priority and pause slots etc.
6 GPU Folding Rig  Linux Folding HOWTO Folding Remote Access Folding GPU Profiling ToU Scheduling UPS
Systems:
desktop: Lian-Li O11 Air Mini; Asus ProArt x670e WiFi; Ryzen 9 7950x; EVGA 240 CLC; 2 x 48GB DDR5-6000; 2 x Samsung 980 Pro 500GB PCIe3 NVMe; 2 x 8TB NAS; MSI RTX 4070 ti Super; AMD FirePro W4100; Corsair SFF750
nas1: Fractal Node 804; SuperMicro X10sl7-f; Xeon e3-1231v3; 4 x 8GB DDR3-1666 ECC; 2 x 250GB Samsung EVO Pro SSD; 7 x 4TB Seagate NAS; Corsair HX650i
nas2: Synology DS-123j; 2 x 6TB WD Red Plus NAS
nas3: Synology DS-224+; 2 x 12TB Seagate NAS
dcn01: Fractal Pop Silent XL; Gigabyte Aorus z570 Master; Ryzen 9 3950x; AMD Wraith; 2 x 16GB DDR4-3200; 256GB NVMe; Gigabyte Gaming RTX 4080 Super; MSI 4070 Ti Super Gaming X; Corsair RM750e
dcn04: Fractal Define S; Gigabyte Aorus ax570 Master; Ryzen 9 5950x; BeQuiet! PureRock 2; 2 x 16GB DDR4-3200; 250GB NVMe; ; Gigabyte Gaming RTX 4080 Super; MSI 4070 Ti Super Ventus 2; Corsair TX750M
When you get this sorted out please mark the topic as answered so we know it's all straightened out.
Thanks for participating.
Systems:
1 hour ago, Lenovo1984 said:
What browser are you using?
1 hour ago, Metallus97 said:
Does advanced control work?
Browser control is also not really working fine for me either
There's no icon to set up advanced control. The icon in my taskbar disappeared. Switching to Edge did fix the issues with the web control.
interesting. Can you launch the program directly via the exe?
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
I can but only when the control is running from within Edge, I tried it with Chrome again, same issue and the FAHControl.exe would start up but not connect.
It seems to only work when I open the web control via Edge manually.
Verry interesting!  On my system the exe starts no matter whats going on with he web control
