Hello my fellow humans
I am in a bit of a pickle, since my trusted samsung gear iconx 2018 earbuds have perished.
As such, I am looking for a simuliar pair of earbuds, preferably with the same control scheme, since i often use just one at a time
Controls:
tap to pause
double tap to skip
triple tap to go back a song
swipe up to increase volume
swipe down to decrease volume
Any suggestions?
https://linustechtips.com/topic/1109616-wireless-earbuds-recommendations/
Controls:
tap to pause
double tap to skip
Any suggestions?
Why not get another pair?
21 minutes ago, RandomGeekyGuy said:
i am considering that, but I was wondering if there were a better alternative
If you're on a budget - Galaxy Buds would be a good choice. If you have more money to spend, I'd go for the Sony WF-1000XM3.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
Not a big fan of the individual control of the Sony WF-1000XM3, and arent the samsung buds fragile?
The Sony ones are about the sound quality and active noise cancellation, I bet you could get used to the controls. They're too big for my personal taste though (Shrek syndrome) so I jumped on the Galaxy Buds because I like the Harman sound and how it's configured. The Galaxy Wear app is great too, easy to use etc. Headphones come a lot to personal preference so recommendations are tough.
I suppose the Galaxy Buds are just as fragile as any other TW earbuds.
There certainly might be, I just happen to own the ones that died on you and like them a lot. Though one of the pieces sometimes goes out randomly so perhaps mine might follow suit to yours...
Do you know of a pair with simuliar control schemes? The ability to control the volume with a swipe is something i can only find on the iconx
I hear the Pixel Buds have those gestures, though the reviews on them are pretty mixed.
