Question for cable management
Go to solution Solved by RollinLower,
yeah that should be okay. the only thing you need to watch out for is that when the cables are too thick, you can bend the mobo out of shape.
2 minutes ago, MrJunez said:
So i have a case where the psu mounts from the top now if i wanted to hook up a gpu would it be okay to run the cable connector behind the motherboard if its long enough?
yeap, it's ok to run the GPU power cable behind the motherboard tray.
Yikes ill have to find out if my cable is even long enough, plan on getting the new nitro and i have a corsair 650w psu
