Hello to you all and as the title said I need help. recently i upgraded my msi gtx 1060 to an rtx 2070 super. everything was going smoothly in the installation, until i downloaded the drives and a bunch of white horizontal line started to spear and disappear constantly from my screen. my guess is that there is something wrong with my nvidia drives because when I uninstall them using display driver uninstaller everything went back to normal. Than I tried to install them again and same problem.
any idea as to whats going on?
Specs
CPU:I5 8600k
Cooler: CM EVO 212
MB: Asus Prime z370-p
RAM:16GB
HDD: WD blue 1TB
PSU: Corsair RMx 650W 80+ Gold
https://linustechtips.com/topic/1108518-well-i-need-help/
Welcome to the forums!
Let's try this for a start: Download and run Display Driver Uninstaller ( https://www.wagnardsoft.com/DDU/download/DDU v18.0.1.8.exe direct download link).
It will ask you to restart into Safe Mode, do so and use it to wipe all GPU drivers.
That should clean any remaining files from old drivers that might cause issues. Afterwards, install the driver again and get back to us to see if that solved the problem.
Cheers!
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/1108518-well-i-need-help/#findComment-12925146
Cheers!
Should I also uninstall the intel ones ???
https://linustechtips.com/topic/1108518-well-i-need-help/#findComment-12925163
1) check if your graphics card is seated properly into the motherboard and clipped into place and isn't leaning or things like that.
2) make sure that the display cable you're using isn't loose.
3) uninstall every driver via DDU except the intel ones because if you uninstall every display driver you cant get a display output any more and you wont be able to use your computer for new drivers. also as far as i know, the intel drivers are for motherboard display output. they shouldn't affect the graphics card.
4) install new drivers from Nvidia website.
5) if above doesn't work then try putting the card into a different PCIE slot.
It is said that an Italian dies every time Spaghetti is broken.
That's why I break mine twice.
https://linustechtips.com/topic/1108518-well-i-need-help/#findComment-12925169
The intel graphics drivers? yeah.
Computer Specs:
https://linustechtips.com/topic/1108518-well-i-need-help/#findComment-12925178
Ok I did all your steps but still the same issue remains
https://linustechtips.com/topic/1108518-well-i-need-help/#findComment-12925229
