need OBS help
Go to solution Solved by Skiiwee29,
2 minutes ago, Fushiatic said:
GPU: MSI armoured rx 580 (8gb)
CPU: Ryzen 5 3600
RAM: 2x8gb ddr4 vengeance
PSU: 600W (don't know the name)
MOBO: ASRock B450M PRO4
so Rainbow Six Seige is a horrible game for CPUs. Try switching your encoder to GPU or limit your in-game FPS to have CPU overhead so it can actually record the video at 40000 bit rate. You could also try lowering the bit rate down a bit and work your way up from there to find out what you can handle.
i have no idea why, but whenever i record rainbow on my OBS it looks god awful in the mp4 file, i've looked up setting options and all that but it still just looks awful
Post Screenshots of your OBS settings please as well as detailed hardware info for your PC.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1106774-need-obs-help/#findComment-12910966
CPU: Ryzen 5 3600
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1106774-need-obs-help/#findComment-12910986
thanks
https://linustechtips.com/topic/1106774-need-obs-help/#findComment-12910989
