System Specs:
CPU: i7-8700k@4,3ghz
GPU: MSI Ventus RTX 2080
RAM: Corsair Vengeance LPX 16GB DDR4-3000mhz CL15 (dual channel)
Mobo: Asus Rog Strix B360-F Gaming
Cooler: Corsair H100i pro
So my problem is that my CPU is most of the time at 100% usage and my GPU at 65-70%. I play on Ultra preset and 1080p. Most of the time i have around 150 fps and it even drops sometimes below 90fps. Latest BIOS and driver for the GPU are installed. Tried to reinstall windows but that didn't change anything. I know this game is meant to use all cores and use them as much as possible, but with a 8700k and a 2080 i should get way more fps.
CPU temp is also fine.
Can anyone help me?
https://linustechtips.com/topic/1106069-bottleneck-issues/
and what game are you talking about?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1106069-bottleneck-issues/#findComment-12905897
I can help, and it's really easy for you to do. Just use a 1440p or 4K monitor, and the problem will go away.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1106069-bottleneck-issues/#findComment-12905909
Prolly overclock the cpu as much as you can. Maybe use an FPS cap.
I have the same issue. Was thinking of making another rig as using 1440 is just a handicap I’d rather avoid.
https://linustechtips.com/topic/1106069-bottleneck-issues/#findComment-12906152
base clock is 3.7ghz. I tried the open beta from CoD today and there i have over 144fps the whole time. I don't mind the CPU being at 100% but the FPS drops shouldn't be like that
https://linustechtips.com/topic/1106069-bottleneck-issues/#findComment-12909276
Those statements completely contradict each other.
https://linustechtips.com/topic/1106069-bottleneck-issues/#findComment-12909705
11 hours ago, Sir_SlaYeR said:
i mean that i should have way higher average fps than the ~150 fps with drops to the ~100 fps
Can’t have more with a cpu at 100 normally.
https://linustechtips.com/topic/1106069-bottleneck-issues/#findComment-12912010
