Hello!
I recently upgraded my rig to an itx build since I am moving around a lot. I will list my parts below. I tried to keep my Cryorig h7, but don't have the backplate for it and it does not look like it fits. I switched to amd4 cpu and need a compact cooler since space is limited. I have 2 intake fans and one out. I am currently using the stock cooler, but it is maintaining mid 70s and occasionally 80 when playing games. Im currently running it without the clam shell cover to help cool it down...
Any help is much appreciated!
My build:
-mobo: ROG strix b450-i
-cpu: ryzen 5 3600
-case: core 500
-gpu: Nvidia FE 2070
https://linustechtips.com/topic/1105098-core-500-itx-cooler/
The H7 should easily fit. Some examples here: https://pcpartpicker.com/builds/by_part/93Crxr#e=958
Have you tried contacting Cryorig for an AM4 bracket?
https://linustechtips.com/topic/1105098-core-500-itx-cooler/#findComment-12897699
