You will burn one up.  You are creating resistance.  You need to run them in a series and be the same RPM/Flow.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1103866-walter-cooling-pump/#findComment-12888087
On 9/12/2019 at 4:29 PM, Evakuierter said:
Hi,
i just wanted to ASK wahr would happen if you added a second pump into your water cooling loop. I mean not same type of pump but a different one with different specs.
Thanks you for your time.
As said it's not recommended to use different pumps in series as you will be forcing one pump or the other, while it can work it's not ideal.
https://linustechtips.com/topic/1103866-walter-cooling-pump/#findComment-12890568
Hi!
But what about using 2 pumps with the same specs? I mean, I was planning to use 2 D5 pumps.
The idea I had was to connect both pump outlets to a small reservory with multiple inlets and outlets, then from one outlet in that reservory send a line to the motherboard/cpu block and the other one to the gpu 1 & 2, and finally join the outlets from mobo/cpu and gpus with a T to the first rad and follow the loop.
To clarify: P1 & P2 > small res acting like a distribution plate > 1st outlet to mobo/cpu > 2nd outlet to gpu 1 + gpu 2 > join these outlets to rad 1 > rad 2 > 2nd "normal" reservory > return again to P1 & P2.
Will this work? Will have any performance or I should go instead for a serial dual pump housing?
Thanks in advance.
https://linustechtips.com/topic/1103866-walter-cooling-pump/#findComment-12891200
15 hours ago, santidns said:
Hi!
Thanks in advance.
Two pumps in series will help in terms of pressure but splitting your flow between the GPU and CPU isn't really necessary especially since the restriction between those block will need to be similar to ensure even flow.
https://linustechtips.com/topic/1103866-walter-cooling-pump/#findComment-12892425
On 9/12/2019 at 10:29 PM, Evakuierter said:
Hi,
Hi!
Thanks in advance.
Even one pump can move a ton of water. My D5 runs at 30% RPM with two 360 rads, a cpu block and gpu block. You dont need a second pump if your first one is decent.
https://linustechtips.com/topic/1103866-walter-cooling-pump/#findComment-12892436
