I know 200mm fans aren't the best, but I will be getting the 650d and heard that the front intake fan is loud, top exhaust will be replaced, with h100i, since there is no mounting can anyone recommend a half decent 200mm fan, I was thinking maybe http://www.amazon.com/BitFenix-Cooling-Cae-Fan-BFF-SPRO-20025KK-RP/dp/B007OWPFUM/ref=sr_1_2?ie=UTF8&qid=1391401396&sr=8-2&keywords=bitfenix+200mm+fan, that fan, but I'm not to in the know about fans, all I know noctua and corsair don't have any. Is that one good, or should I look at another one, if the stock fan will wind up being fine Ill stick with it but I doubt it?
Mouse: Razer Death Adder 2013 Keybaord: Razer Black Widow Ultimate 2013
https://linustechtips.com/topic/110374-200mm-fans/
The Bit Fenix Spectre Pro 200mm is crap. Don't buy it.
Go with the Coolermaster Megaflow instead.
http://www.amazon.com/Cooler-Master-MegaFlow-200-Computer/dp/B008G3OLRQ/ref=sr_1_1?ie=UTF8&qid=1391401664&sr=8-1&keywords=coolermaster+200mm
It's quiet and moves a good amount of air.
https://linustechtips.com/topic/110374-200mm-fans/#findComment-1474292
