So I got myself a Corsair Vengeance 750M (Used) but no cables were included, can I buy Corsair SATA Type 4 (Gen 3) which is compatible with these (RMi - RMx - SF). I'm unable to find which "Series" my psu is, nor do I understand anything from corsairs chart of "psu cable compatibility". Help :S
https://linustechtips.com/topic/1102568-cable-compatability-for-powersupply/
You've got a Vengeance series PSU and you need Type 3 SATA/PATA cables and Type 3 OR Type 4 PCIe cables
https://www.corsair.com/us/en/psu-cable-compatibility
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
2 minutes ago, Lurick said:
Not sure how it's confusing? You've got a Vengeance series PSU and you need Type 3 SATA/PATA cables and Type 3 OR Type 4 PCIe cables
Only compatible cable is Type 4 PCIe the rest are all fixed (Black dot = fixed cable)
I was about to edit with that but then I saw a picture of the PSU itself and it proves that incorrect because it has non-fixed cables for sata
Prior Build Log/PC:
My SATA/PATA cable is not fixed. But back to the original question, as I'm Swedish there are not alot of options when ordering cables from swedish stores. Would a Corsair SATA Type 4 (Gen 3) be fine or would that make my ssd a baloon?
I believe you'll be fine. I found a few threads on reddit about Type 3 vs Type 4 and it seems they are the same for all corsair PSUs
Prior Build Log/PC:
