Quantity of fans in my build.
2 or 3 fans should be plenty.
Depending on how tight the cables are against the bottom of the motherboard, you can fit 1-2 bottom intakes under the graphics card. Along with a rear exhaust, that should be plenty for airflow.
SW3's are excellent but the pricing is a bit high.
I'd recommend going with some cheaper alternatives like NF-P12's for bottom intake and NF-S12B for rear exhaust.
https://pcpartpicker.com/product/VNBTwP/noctua-nf-p12-redux-1700-pwm-708-cfm-120mm-fan-nf-p12-redux-1700-pwm
https://pcpartpicker.com/product/bKFPxr/noctua-case-fan-nfs12bredux1200pwm
