hey guys i am trying to push my Samsung S9 + audio to the PC via an Aux Cable when i plug my Aux cable into Line In on the MOBO there is a static noise which is due able but as soon as i connect my Phone to the PC via USB while aux cable is plugged in it makes that static noise louder which is not good since i wanna record gameplay audio..
what can i do to fix this issue
https://linustechtips.com/topic/1101247-static-noise/
HI, I have experienced recently exactly the same problem. In my case I thought it was due to the mains, as the noise was present when using an external headphones amplifier which is powered through the mains. But then I tried using my USB DAC/amp as a pure headphone amp only (lineout of the PC connected and then power over USB) and the same noise was present, with possibly the ground loop going through the USB. The noise of course was not there if I was only connecting a DAC/amp over USB or the headphones directly on the PC, as there is no loop.
I think in your case you are creating a ground loop with your configuration, hence the noise.
I had to give up and find a decent ground loop isolator. To avoid cheapo things using bad audio transformers, I narrowed down my search on the Monacor FGA-40HQ. That removed the noise completely and the audio quality is transparent IMHO, which is what you want.
A device like this is about £15 here in UK. Don't get cheapo things as they might compromise your sound. And don't do any "earth lifting" on your devices to bypass similar issues as some suggest on the internet, as you would put yourself and others at risk when doing so.
https://linustechtips.com/topic/1101247-static-noise/#findComment-12868129
Monacor make pretty nice budget stuff. Got a couple of their SA-50 amp's for testing stuff out on.
LTT's Resident Porsche fanboy and nutjob Audiophile.
Main speaker setup is now;
Mini DSP SHD Studio -> 2x Mola Mola Tambaqui DAC's (fed by AES/EBU, one feeds the left sub and main, the other feeds the right side) -> 2x Neumann KH420 + 2x Neumann KH870
(Having a totally seperate DAC for each channel is game changing for sound quality)
https://linustechtips.com/topic/1101247-static-noise/#findComment-12868339
