Hi guys,
I recently broke my XBox One Controller cabel and was wondering if something like that (magnetic USB cable)
would work with the controller to use it one the PC?
(I dont want to by a wireless adapter because it is more expensive and I want to charge my controller with the cable)
Thanks in advance!
https://linustechtips.com/topic/1101168-will-it-work/
3 minutes ago, SimonSchnurrbart said:
Hi guys,
Thanks in advance!
Yea it’d work but it might fall out while your playing if you move the controller a lot. I swear you can buy a usb lead for 99p of eBay just buy a normal one.
https://linustechtips.com/topic/1101168-will-it-work/#findComment-12865074
